Para centralizar um pouco as dicas de ferramentas uteis
Live Streaming & Recording Software - XSplit
Live stream and record your content with ease & share it to streaming services like Twitch, UStream, Hitbox and YouTube.
O lucas (do houdini) usou essa ferramenta para gerar um screen capture e eu achei super legal
então decidi compartilhar ela com vcs caso precisem fazer isso em algum momento
ShareLaTeX, Online LaTeX Editor
Latex is a document preparation system for high-quality typesetting. It is most often used for medium-to-large technical or scientific documents but it can be used for almost any form of publishing.
An online LaTeX editor that’s easy to use. No installation, real-time collaboration, version control, hundreds of LaTeX templates, and more.
HackMD - Collaborative markdown notes
Markdown is a lightweight markup language with plain text formatting syntax designed so that it can be converted to HTML and many other formats using a tool by the same name.
HackMD is the best way to write and share your knowledge in markdown.
Snipping Tool in windows
Windows conta com uma ferramenta que permite criar um screen capture seletivo.
Stack Edit - Online Markdown Editor
Stack edit is very easy to use markdown editor with ability to publish documents as HTML, Markdown or PDF. It features 2 panes, with markdown text and rendered result side by side, which makes it very easy to learn and use.
You can create TOC (Table of Contents), write mathemathical expressions in LaTeX, create UML diagrams and write whatever type of document.
Gliffy - Online diagraming tool
Gliffy is online and easy to use diagraming tool, which can be used to draw flowcharts, mind maps, UML, network diagrams, or any other kind of diagram. Diagrams can be shared with your team in collaborative manner. It has nicely designed presets to get you quickly up to speed.
You can export to different formats, such as JPG, PNG, SVG and others.
Draw.IO - Online diagraming tool (Open Source)
draw.io is another online diagraming tools, but it is completely free and open source. You can create any type of diagram, and it also comes with a lot of presets.You can save to Google Drive, or to Local device and export in various formats such as JPG, HTML, PDF
Wekan - Opensource Kanban board (Trello-like)
Wekan is open source kanban board, heavily inspired by Trello. It shares many of the same features but it’s completelly free, and can be hosted on-premise. Create lists, cards, labels, write comments and export board for archiving.
Editor gratuito e web, sem necessidade de instalação, para visualização de texto no formato Markdown do próprio GitHub:
