Quando acontece esse erro na renderfarm num render de Maya 2017:
–[vzRenderWatcher]–Error: The transforms path found in the configuration file does not exist: C:/Users/matheus.ruiz/AppData/Roaming/VetorLobo/MayaAppDir/2017/prefs/synColorConfig.xml
–[vzRenderWatcher]–Error: The SynColor package is not installed: C:\ProgramData\Autodesk\Synergy\SynColor\2017
–[vzRenderWatcher]–Warning: Parameter was not found: input_space
–[vzRenderWatcher]–sys:1: UnicodeWarning: Unicode equal comparison failed to convert both arguments to Unicode - interpreting them as being unequal
–[vzRenderWatcher]–Warning: View transform name “sRGB gamma” is not defined in the transform collection. Using default value “sRGB gamma”.
–[vzRenderWatcher]–Error: Failed to apply color management settings on file open: View transform sRGB gamma is unknown…
–[vzRenderWatcher]–Error: View transform sRGB gamma is unknown.
–[vzRenderWatcher]–Fatal Error. Attempting to save in C:/Users/MATHEU~1.RUI/AppData/Local/Temp/matheus.ruiz.20180724.2247.ma
Precisamos copiar esse arquivo de uma máquina onde o Maya 2017 já foi aberto:
C:\Users\claudia.fujiwara\AppData\Roaming\VetorLobo\MayaAppDir\2017\prefs\synColorConfig.xml
