2449 - Yeti 2.1.3 for Maya 2016
Release date: 2016-11-29 at 12:47:54
Yeti 2.1.3
Released: 19/11/2016
Dependencies: MtoA 1.4.0.0, Arnold 4.2.15.2, VRay 3.40, RMS 21.1, PRMan 21.1, 3Delight 12.0.113, Redshift 2.0.71
__
Changes:
  • inherited attributes in the Grow node are now correctly allocated.
  • resolved memory leaks related to VP2.0 implementation.
  • feathers are correctly update when vertices are edited.
  • updated MtoA extension to be compatible with MtoA 1.4.0 API.
  • surface UVs are set as default for Redshift.
  • additional UV set named featheruv exported for Redshift which can be accessed via the UV Set Override on the Place 2D Texture node.
  • fixed an issue where object ids werent being maintained when read from a cache.
  • fixed feather proxy drawing in shaded view.
...\VetorLobo\Maya2016\modules-x64\modules\mtoa-1.0\mtoa.mod
...\VetorLobo\Maya2016\modules-x64\modules\mtoa-1.0\readme.txt
...\VetorLobo\Maya2016\modules-x64\modules\renderfarm\mtoa-1.0\mtoa.mod
...\VetorLobo\Maya2016\modules-x64\modules\renderfarm\mtoa-1.0\readme.txt
...\VetorLobo\Maya2016\modules-x64\modules\yeti-2.1.3
...\VetorLobo\Maya2016\modules-x64\modules\yeti-2.1.3\bin
...\VetorLobo\Maya2016\modules-x64\modules\yeti-2.1.3\bin\pgYetiArnold.dll
...\VetorLobo\Maya2016\modules-x64\modules\yeti-2.1.3\bin\pgYetiCacheInfo.exe
...\VetorLobo\Maya2016\modules-x64\modules\yeti-2.1.3\bin\pgYetiDLGenPTC.exe
and 155 more files
